G31 on Mach3
Posted: Fri Feb 12, 2016 11:41 am
Well I've not even probed anything yet, only tried a 'simulation'.
The line:
G31 Z-10 F100
causes Mach3 to keep lowering the tool position indefinitely - er well I stopped it at -70mm.
I assume that Z should go to -10mm and then stop. Is that correct, or could there be a Mach3 setting or other problem causing this?
The line:
G31 Z-10 F100
