Exception when trying to oepn directory
Report problems here
dogeroski
Postby dogeroski » Sat Feb 04, 2017 2:20 pm
OS: MacOS
Steps to repro:
1. Browse for a file on a external drive.
2. Open the file.
3. Unmount the external drive.
4. Try to browse for a new file.
Expected result: Opens for example user home directory as the unmounted drive is no longer valid.
Actual result: Throws an exception as it tries to open an invalid directory.
Stack trace:
Exception in thread "JavaFX Application Thread" java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
	at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1774)
	at javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1657)
	at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
	at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238)
	at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
	at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
	at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
	at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
	at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
	at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
	at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49)
	at javafx.event.Event.fireEvent(Event.java:198)
	at javafx.scene.Node.fireEvent(Node.java:8411)
	at javafx.scene.control.Button.fire(Button.java:185)
	at com.sun.javafx.scene.control.behavior.ButtonBehavior.mouseReleased(ButtonBehavior.java:182)
	at com.sun.javafx.scene.control.skin.BehaviorSkinBase$1.handle(BehaviorSkinBase.java:96)
	at com.sun.javafx.scene.control.skin.BehaviorSkinBase$1.handle(BehaviorSkinBase.java:89)
	at com.sun.javafx.event.CompositeEventHandler$NormalEventHandlerRecord.handleBubblingEvent(CompositeEventHandler.java:218)
	at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:80)
	at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
	at javafx.scene.Scene$MouseHandler.process(Scene.java:3757)
	at javafx.scene.Scene$MouseHandler.access$1500(Scene.java:3485)
	at javafx.scene.Scene.impl_processMouseEvent(Scene.java:1762)
	at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2494)
	at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:352)
	at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:275)
	at java.security.AccessController.doPrivileged(Native Method)
	at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$354(GlassViewEventHandler.java:388)
	at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:389)
	at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:387)
	at com.sun.glass.ui.View.handleMouseEvent(View.java:555)
	at com.sun.glass.ui.View.notifyMouse(View.java:937)
Caused by: java.lang.reflect.InvocationTargetException
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:71)
	at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
	at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:275)
	at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1771)
	... 53 more
Caused by: java.lang.IllegalArgumentException: Folder parameter must be a valid folder
	at com.sun.glass.ui.CommonDialogs.convertFolder(CommonDialogs.java:238)
	at com.sun.glass.ui.CommonDialogs.showFileChooser(CommonDialogs.java:190)
	at com.sun.javafx.tk.quantum.QuantumToolkit.showFileChooser(QuantumToolkit.java:1496)
	at javafx.stage.FileChooser.showDialog(FileChooser.java:416)
	at javafx.stage.FileChooser.showOpenDialog(FileChooser.java:350)
	at com.cncsoftwaretools.autoleveller.ui.controllers.BasicsTabController.findOGF(BasicsTabController.java:104)
	... 63 more
	... 53 more
	... 63 more
Re: Exception when trying to oepn directory
Postby daedelus » Fri Feb 10, 2017 2:58 pm
Sorry for the late reply, been bombarded with email queries lately so been somewhat distracted.
Thankyou for the details, I will log this issue and fix when possible.
dogeroski
Postby dogeroski » Fri Apr 21, 2017 3:07 pm
Hey there. Any update on the issue? It's still present in the latest version. Currently it renders the app useless for me as I can't open anything as it crashes when trying to open the browse dialog :/
Postby daedelus » Sat Apr 22, 2017 5:43 pm
A possible workaround / fix...
I presume you are using AutolevellerAE v0.8.2?
There should be a file "settings.xml" in your user home folder/.AE
You should see an entry there "defaultDir"... delete that entire line and AE should recreate it with your base user.home folder next time you restart AE.
You should be able to delete the "settings.xml" file also.
I do not have a Mac to test on but it should work. Let me know if not.
Who is online
Users browsing this forum: No registered users and 1 guest
