Hello. I use Autoleveler 0.8.6 on computer with Russian  localization. CNC running MACH3. After a failed try to load in PCB milling Autoleveler obtained from machine RPF file, but ALWAYS get the error:
23:19:33 [INFO] Autoleveller-Application started
23:19:41 [WARN] AutolevellerGUI $-Please set a valid GCode file first
[INFO] 23:19:46 AutolevellerGUI $-Unmodified GCode File (UGF) set to "D:\CAN_BUG\PCB\NC\4x4.tap"
23:20:13 [INFO] AutolevellerGUI $ 4-Work area is: X = 0 Y = 0 X = width Y = height 160.78 112.77
23:21:19 [INFO] AutolevellerGUI $ 5-Raw Probe File (RPF) set to "D:\CAN_BUG\PCB\NC\AL4x4.txt"
23:21:19 [ERROR] Probe-An error occured whilst reading from the RPF, see full log file for more details
Tried on different computers, the result is the same. Sorry of my English. Thanks.
						AL 0.8.6 ERROR on load RPF
Re: AL 0.8.6 ERROR on load RPF
Sorry for the late reply on this, I have been busy working on the new AL8 which you may or may not have seen.
Anyway, first I thought this may have been a problem with the tolerance setting (where X and Y axis read from the RPF can be slightly offset from the given value), as was reported by another user. But looking at the RPF you sent me this does not seem to be the case as there seems to be other problems with it and is why AL is having problems reading from it.
Each column represents the X, Y and Z axis of each probe point but there seems to be some issues with it. I have commented on some but not all of the lines in the RPF.
In summary, there seems to be some lines missing and have been replaced with duplicates of other lines, which is the reason AL shows errors.
Not sure why these logging issues appear in Mach 3, anyone got any ideas?
0.00000,0.00000,0.00500
8.01500,0.00000,0.04500
16.02500,0.00000,0.05500
24.04000,0.00000,0.07000
24.04000,0.00000,0.07000 (duplicate of the previous line)
40.07000,0.00000,0.16500
48.08000,0.00000,0.20500
48.08000,8.01000,0.23500
48.08000,8.01000,0.23500 (duplicate of the previous line)
32.05500,8.01000,0.15000
24.04000,8.01000,0.11000
16.02500,8.01000,0.09500
16.02500,8.01000,0.09500 (duplicate of the previous line)
0.00000,8.01000,0.03000
0.00000,8.01000,0.03000 (duplicate of the previous line)
8.01000,16.02000,0.08500
16.02500,16.02000,0.10000
16.02500,16.02000,0.10000 (duplicate of the previous line)
32.05500,16.02000,0.16000
40.07000,16.02000,0.19000
48.08000,16.02000,0.24000
48.08000,24.02500,0.25500
40.07000,24.03000,0.19000
32.05500,24.03000,0.15500
24.04000,24.03000,0.10500
16.02500,24.03000,0.08500
8.01500,24.03000,0.05500
0.00000,24.03000,-0.03500
0.00000,32.04000,-0.04000
8.01500,32.03500,0.02000
16.02500,32.04000,0.07000
24.04000,32.03500,0.10000
32.05500,32.04000,0.14500
40.07000,32.03500,0.21500
48.08000,32.04000,0.26000
48.08000,40.04500,0.26500
48.08000,40.04500,0.26500 (duplicate of the previous line)
24.04000,40.04500,0.11000 (missing lines starting with 40.07000 and 32.05500)
24.04000,40.04500,0.11000 (duplicate of the previous line)
8.01500,40.04500,0.00500 (missing line starting 16.02500)
0.00000,40.04500,-0.07000
0.00000,48.05500,-0.11500
0.00000,48.05500,-0.11500 (duplicate of the previous line)
24.04000,48.05500,0.10000
32.05500,48.05500,0.16000
40.07000,48.05500,0.23000
48.08000,48.05500,0.29000 In summary, there seems to be some lines missing and have been replaced with duplicates of other lines, which is the reason AL shows errors.
Thank you very much. I will look for the source of the problem in the Mach3. On the results reported in this forum thread. Regards. NacK.
P.S. It would be nice if the Autoleveler in such situations would generate more meaningful error message such as "RPF file data is corrupted (unreliable); line ####"
