Neither opening GCode or saving AL output
Posted: Tue Aug 16, 2016 11:01 pm
by Gasman2016
OS X 10.11 (El Capitan). Java 1.8 (latest updates - but have also tried with Java 1.6 and 1.7)
I have downloaded versions AutolevellerAE-0.7.0Free.jar, Autoleveller077 and Autoleveller074 (and a couple of sample Gcode files just to check it is not my GCode that is the problem) but am unable to use any of them.
Running AutolevellerAE_0.7.0Free - I am told that there is a later version available and when I dismiss this then it displays the file selection pane - when I click on 'Browse' nothing happens - I cannot select a file nor can I type a path into the box. Game over...
Running the 074 and 077 versions, I a am also reminded of a more recent version and I can then select a file in the browser pane. The figures on the 'probe' section do not fill after I select a file, nor does the G code info section. If I manually enter some figures into the probe section, it calculates the number of points. When I try to 'Create level code' I am taken to the 'Save' dialogue with the ALxxxx.ngc file selected however, no file is produced. If I click new folder, a new folder is made - if I then click save, still no file is produced.
I am trialling the free version and would be quite happy to pay for the members version - but only if it is going to work!
Any ideas?
John
Re: Neither opening GCode or saving AL output
Posted: Thu Aug 18, 2016 10:36 am
John,
Thanks for the detailed info. The problem here is with OSX. Java should be platform independent but it seems, browsing for files does not work properly on a Mac, as I seam to remember a similar problem years ago with a Mac user. Unfortunately, I cannot test it on a Mac currently.
If you can get hold of a windows / linux box to test it on, all versions of AL / AE should be fine from there.
