Linux Mint :Autoleveller model AE does not work (while the non-AE version works)
jeffou66
Post by jeffou66 » Wed Dec 18, 2019 8:10 pm
Autoleveller model AE does not work (while the non-AE version works) on linux (Linux Mint 19.1 Tessa) with preempted kernel. I directed to Java 1.8.xx (I also have java 11 available but neither normal nor AE worked with.
I just tried on another machine with the same system and it works >> would the preempted kernel be a problem?
Do you have a solution to operate the AE version?
resulted from: java - version:
openjdk version "1.8.0_232"
OpenJDK Runtime Environment (build 1.8.0_232-8u232-b09-0ubuntu1 ~ 18.04.1-b09)
OpenJDK 64-Bit Server VM (build 25.232-b09, mixed mode)
Thanking you in advance.
Fabrice
P.S. I am etching PCB in 0.1mm and I would like to try your software which looks superb with LinuxCNC, my Gcode make up to 50,000 lines for small cards.
