Quick video
Discuss all things
booski
Quick video
Post by booski »
https://www.youtube.com/watch?v=xbD0d5_UJwI
Bout it will, will elaborate later!
Re: Quick video
Always good to "geek out" on CNC videos :D
Out of interest, what is the speed of the spindle in the vid?
booski
Re: Quick video
Post by booski »
Speed is about 25k rpm. It would go more if I set the power supply the extra half a volt or so that's left on the adjuster but then I start getting more harmonics than what I already do.
booski
Re: Quick video
Post by booski »
I did just bump the voltage to the maximum and got 27,000 RPM out of the spindle. I don't think the o-ring belt would have lasted long at that though, looked like it was about to fly off!
Re: Quick video
Would love to get something that fast.
8k is the max. of my lame spindle. :(
booski
Re: Quick video
Post by booski »
You know what, this spindle is quite possibly the simplest spindle ever.
It's it literally an 8mm diameter ER11 extension, 2x 608 bearings, 22mm aluminium tube all pressed together and a pulley I turned myself. at 25K RPM it barely gets warm to the touch when milling, the motor has a built in fan to keep itself cool and runs off a 12V supply. Never run it above 33K RPM because that's the bearings maximum speed and yeah, it does get hot then. I've had a past version up to 55k RPM with a brushless motor which I've still got actually but by christ it's noisy and get's very hot.
The machine itself came with a crappy damaged spindle that would top out at 8k on 48V and was entirely worthless. I pinched the spindle off my college project, make a couple of reducers for the spindle clamps, a mount for the motor and an O-ring for a pulley.
