Mach3
Posted: Fri Apr 20, 2018 7:28 pm
Hey!
Does this work for Mach3?
Do I have to install a probe? Or can I just zero at a corner then punch in values for the other three corners?
Is it a script that inserts ahead of whatever gcode you've generated that uses variables or something to modify the code?
Or do you run a program on your machine to get the coordinates then given that the software edits your g-code?
