Manual Tool Change
sonolink
Manual Tool Change
Post by sonolink »
I apologize if this has been posted alredy but I did a search and couldn't find any answer.
I want to set up Mach3 to allow for Manual Tool Change, so that in one G-Code I have different bits one after another. When Mach3 pauses to allow for the tool to be changed and waits for Cycle Start to be pressed to continue with the G-Code I need to re-probe Z to set the new length of the tool.
My question is: does this affect Autoleveller and how should I proceed when calibrating the height map?
Cheers
Sonolink
sonolink
Re: Manual Tool Change
Post by sonolink »
Thanks a lot for all your replies!!
I didn't answer when you posted your question as I do not use Mach!
I can only say that I use Turbocnc and do a single probe and let the post processor for Eagle do all the tool change coding.
I would expect it to work in a very similar way in Mach, but YMMV!
