breakdown lines and arcs
Posted: Fri Jul 24, 2015 12:00 pm
hi,
i really like the autoleveler software and use it a lot.
however i have a little problem with it working together with mach3 tangential control.
in my case i have straight lines to cut with a knife on the cnc. the autoleveler breaks down one line in many smaller g1 segments. mach3 however stopps then at each of this segments. this behavior is only when tangential control is enabled.
is there a way not to break down straight lines in small segments? i am doing many of these cuts on one workpiece so it takes much longer to do the job.
maybe an older version is better suitable or maybe it is easy to change the programm to make the segments longer? in my probe file i use probe distance of 50mm, so if the segments could be in that range that would already help a lot.
thanks,
michael
thanks,
michael
