Autoleveller works, AE does not.
Posted: Tue May 06, 2025 9:07 am
by jmorg1138
Hi. I can't get AutolevellerAE to work, but I can get Autoleveller. I have Java 8 installed. I'm using Windows 11. What is the problem?
Re: Autoleveller works, AE does not.
Posted: Thu May 08, 2025 10:30 pm
At a command prompt, I typed "java -version" and got this...
C:\Users\daede>java -version
java version "17.0.7" 2023-04-18 LTS
Java(TM) SE Runtime Environment (build 17.0.7+8-LTS-224)
Java HotSpot(TM) 64-Bit Server VM (build 17.0.7+8-LTS-224, mixed mode, sharing)
I'm using Win11 too, and AE works OK for me. Is there another computer you can try it on? A laptop, perhaps?
Posted: Sat Jun 07, 2025 4:57 am
by AlCa
Have you managed to solve it? I'm in the same situation — Windows 11, and only Autoleveller works, but Autoleveller AE doesn't.
Posted: Fri Jun 13, 2025 8:13 pm
by MikeAuto
Looks like I am in the same boat, tried on two different machines, both are Windows 11 Home 24H2.
It asks to Java 8 to be installed which I do. When I run the install again, the old, "Do you want this app to make changes to your PC". Clicking Yes, it disappears and nothing appears to be changed.
Running the Autoleveller-0.8.7 at least starts up.
Java -version shows this:
java version "1.8.0_451"
Java(TM) SE Runtime Environment (build 1.8.0_451-b10)
Java HotSpot(TM) 64-Bit Server VM (build 25.451-b10, mixed mode)
Posted: Fri Jun 13, 2025 8:46 pm
by MikeAuto
Tried to run in Command Prompt, I get this:
C:\Users\XXX\Downloads>java -jar AutolevellerAE.jar
Error: JavaFX has been removed from JDK 8.
Visit
https://www.oracle.com/javase/javafx for more information.
Error: Could not find or load main class com.cncsoftwaretools.autoleveller.Autoleveller
Here is what is on the Oracle Website:
JavaFX on JDK
Executive Summary:
Oracle continues to reaffirm its long-standing commitment to the OpenJFX project in OpenJDK.
Commercial support for JavaFX 8 has officially ended and JavaFX has been removed from Oracle JDK 8 and JRE 8 releases as of April 15th, 2025 (8u451 and later).
Organizations with any ongoing JavaFX 8 needs should contact Oracle Support or Java Sales.
Resources:
https://blogs.oracle.com/java/post/the- ... ap-updates
https://blogs.oracle.com/java/post/java ... ap-updates
https://www.oracle.com/technetwork/java ... 548840.pdf
https://blogs.oracle.com/java/post/java ... map-update
Details:
When launched in 2014, Oracle announced an initial support timeline of five years for JavaFX 8. In 2018, Oracle extended the support for JavaFX 8 through to March 2022, and then in 2020, the commercial support for JavaFX 8 was extended a final time through to March 2025.
Meanwhile, Oracle has worked to decouple the JavaFX technology from the JDK and has made it available as open source. We are proud to have already delivered fourteen versions of JavaFX from the OpenJFX project starting with JavaFX 11 in September 2018 through to the latest JavaFX 24 in March 2025, including related security updates along the way. Oracle is reaffirming its commitment to leading the OpenJFX project forward as an important technology for academic and R&D use.
Oracle recommends migrating to Swing or AWT, or taking advantage of the latest feature set available in JavaFX 24 (via the OpenJFX project at OpenJDK) on Oracle JDK 24. We have provided a guide on the OpenJFX wiki to assist developers familiar with JavaFX 8 who have not yet removed the dependency.
Oracle JDK 8u451, released on April 15, 2025, is the first Oracle JDK 8 release that does not include JavaFX. Organizations that require any assistance or additional details should contact Oracle Support (if an Oracle customer), or Java Sales otherwise.
Posted: Wed Oct 22, 2025 8:04 am
by Nest
Hi, I had the same problem. I solved it by installing the java version jdk-8u202-windows-x64.exe
Best Regards
Posted: Mon Dec 29, 2025 1:56 am
by AlCa
