A (rare) Autoleveler Bug?
Posted: Mon Jan 18, 2016 2:37 pm
Hello everybody,
first of all, my thanks to James for this great and helpful software. I've downloaded it from member's section and am now using the 0.8.7 version for leveling my source gcode files for which I have previously created a probing log file. This works fine for top side of my PCB and the result is, as usually, great.
However, when creating a leveled sourced file for the bottom from a probing bot_log file created in advance on my machine, I seem to have a major problem, as the AL shows an error in its log window (see attachment) and refers to its autoleveler.log file for additional info. I attach this log file as well. I also attach the critical bot_log probing file.
My understanding from what I see in the autoleveler.log file is that there is a problem with ranges in the probing log file. Please note, that if done in one go (probing and milling) there is no problem. However, I would have a separate probing file for later use.
James, may be there is an advice you could give me to overcome the issue?
Thank you very much in advance,
Hanry.
Hanry.
