Autoleveller AE: incomplete output file
Posted: Mon Oct 24, 2016 7:02 pm
I have a g-code file of a small circuit board I have designed. The file is made in CamBam and tested to be working.
I have successfully used Autoleveller 0.8.7 (not AE) to create a leveled g-code file out of it.
However, when I tried to do the same with Autoleveller AE 0.7.8, the output file contained nothing but the probing routine. The last line of the output file was "M0 (Detach any clips used for probing)"; the original G-code was missing altogether.
I tried processing a different file in Autoleveller AE, and it worked fine. As far as I can tell, the only major difference between those files is that one of them uses line segments only (G1) and the other one uses lines and arcs (G1, G2, G3). Does Autoleveller AE have issues with arcs?
