using with stepcraft uc100
Posted: Wed Nov 16, 2016 8:35 pm
Just wanted to check on using this with a stepcraft 840 controlled by a uc100. i don't have a port 15 to select as the tool length probe is on port 10 pin 1 as shown in this link here - http://www.stepcraftsupport.com/faq-ite ... th-sensor/
this is a simple micro-switch for tool length for the z axis.
i don't see any where in the last revision of your software that i can assign a port/pin to the auto leveller software, is this possible in the paid version?
I am looking to test this tomorrow so if the paid version does allow this to be assigned then i will buy this tonight.
on your guide there are two wires coming in one with the 10k pull up resistor on and the gnd to the bit that touches the blank pcb.
i am hoping that by having two wires coming out from the tool length terminals on the uc100 card one to the blank the other to the probe(gnd) that it will function correctly with the modified gcode. that your software creates.
thanks
sim
thanks
sim
