Autoleveller doesn't work with USB 6040
Posted: Thu May 18, 2017 6:07 am
I'm using a 6040, 2.2Kw CNC with Mach3 with USB connection. I've tried everything that I can possibly think of:
- Read about the "aircuts with USB mach3" and tried to add those lines
- Became member and downloaded and installed the latest Autoleveller
- Grounded my spindle
- Changed USB cable to high quality
Nothing works.
Before, probing didn't produce any results. The CNC even moved X or Y axis when he was supposed to move Z down for probing. After adding the lines from the aircuts post, it seems he's probing OK. But then starts to cut 2 mm in the air.
I made the decision to invest in a high quality 6040 CNC to be able to make quick PCB prototypes. But it seems Autoleveller is not compatible with Mach3 on a USB connection.
Is that assumption correct?
Nothing works.
