Need advice.
I can generate the probe file successfully and from there generate a corrected Z axis file to use on the CNC machine. But Version 0.8.7 (stuck with Windows XP) insists on using auto probing for Z axis onto a PCB metal surface before starting the final cut. If I try to by pass this (Because I have already set Z axis zero) the G-code runs straight to the end of the script without moving anything on the CNC machine. I would very much like to generate a Z corrected G-code that I can then set my own Z reference externally to the G-code and then just run the Z corrected G-code. I currently use a Mach3 plug-in which is very good at setting the Z reference for me before I start to run the G-Code.
I managed to do this with Version 0.7.7 several months ago, but now I return to it I am completely baffled as to how I did it!!
Must be getting old. BR, Peter Dobson.
Autoleveller for Plastic engraving
Re: Autoleveller for Plastic engraving
Peter,
I also bypass that section as I have my own auto tool length setting system. Not Mach, but I have done it since the beginning of using Autoleveller.
I am using the current version of AE and cannot find a verifiable version of gcode using V8.7 on my hard drive to be able to give you an idea on how to do it. If you could upload a sample of what your doing, I will be glad to look at it and offer (hopefully) a solution.
Another certifiable ole man
Hi Country_Bubba,
Thanks for getting back to me. Having slept on the problem, I tried again today but this time took the generated files from windows XP and then ran AutolevellerAE-0.9.4u2 on a separate Windows 10 machine and generated the required Z corrected files. At the beginning of the g-code I found this:
G90 G21 S20000 G17
(Initialize probe routine)
G0 Z25 (Move clear of the board first)
G1 X20 Y20 F600 (Move to bottom left corner)
G38.2 Z-1 F100 (Probe to a maximum of the specified probe height at the specified feed rate)
G38.2 Z-1 F50 (Repeat at a more accurate slower rate)
M0 (Detach any clips used for probing)
Which I deleted. Now the code seem to run correctly. I don't remember having to do this before and just wondered if there was a tidier way of achieving the same results??
Full z-corrected file enclosed.
Thanks Pete D.
G90 G21 S20000 G17
Thanks Pete D.
- ALG600 engraving.ngc
- (25.04 KiB) Downloaded 302 times
Pete,
Glad to see that you have it sorted out.
Yes that is basically the way I did it. I had a "boiler plate" file that I used to overwrite that section of the code.
The latest version of AE (AutolevellerAE-0.9.4u2) gives you the option of make your own custom Z initialization.
Its under the "member downloads"
Good luck with your engraving.
Thanks,
I'll check out the members download.
Thanks for your advice.
PD.
PD.
