Autoleveller for Plastic engraving
Posted: Tue Mar 27, 2018 9:47 am
Need advice.
I can generate the probe file successfully and from there generate a corrected Z axis file to use on the CNC machine. But Version 0.8.7 (stuck with Windows XP) insists on using auto probing for Z axis onto a PCB metal surface before starting the final cut. If I try to by pass this (Because I have already set Z axis zero) the G-code runs straight to the end of the script without moving anything on the CNC machine. I would very much like to generate a Z corrected G-code that I can then set my own Z reference externally to the G-code and then just run the Z corrected G-code. I currently use a Mach3 plug-in which is very good at setting the Z reference for me before I start to run the G-Code.
I managed to do this with Version 0.7.7 several months ago, but now I return to it I am completely baffled as to how I did it!!
Must be getting old. BR, Peter Dobson.
