Freeze on load OGF
Posted: Mon Jun 04, 2018 11:40 pm
by replic8tor
I am using AutolevelerAE 0.9.4u2. I am trying to load the attached gcode. I get a window saying "Mesh Settings" "Change Mesh Settings" "Do you want to change the mesh settings based on your OGF" When I dismiss the window I still see it and it freezes/locks up saying not responding. What can I do to resolve this issue?
Thanks!
Re: Freeze on load OGF
Posted: Tue Jun 05, 2018 12:14 am
This one beats me. I tried to load it into several versions and got the same results as you. We will need to wait for James to do his magic to figure this one out.
Sorry I can't be more help.
Posted: Tue Jun 05, 2018 4:20 am
by CitizenOfDreams
The answer is simple: your file does not have any cutting moves inside the stock (that is, below Z=0). Change your line 9 to G01 Z-0.0500 and it will load.
Of course, that's not an excuse for Autoleveller to freeze, it should handle situations like that more gracefully.
Posted: Tue Jun 05, 2018 10:14 am
Yes, Just to confirm, AE assumes Z0 is the surface of the stock so any negative Z move puts the tool below the surface and must be a cutting move.
I am looking into a more graceful method of returning from a "non-cutting GCode file"
cheers.
Posted: Mon Aug 20, 2018 12:20 pm
by MartinD
daedelus wrote: ↑Tue Jun 05, 2018 10:14 am
you will love PhenGold and is the surface of the stock so any negative Z move puts the tool below the surface and must be a cutting move.
cheers.
Was the freeze issue fixed btw? I'm going to be using this feature a lot so I'd like to make sure.
