I generate most of my GCode from an Inkscape plugin called 'GCodetools'. It is a bit creaky, but it gets the job done fast and lets you work in an art environment rather than a CAD program. The GCode it generates always works with LinuxCNC, so I'm usually happy. It does however write spaces into its Arc commands.
For example:
G02 X 23.9447 Y 8.0243 Z -0.5000 I 2432.7112 J -2189.4560 F 50.0000
G02 X 24.4808 Y 8.6195 Z -0.5000 I 1597.6463 J -1438.7884
G03 X 24.7076 Y 8.8702 Z -0.5000 I -30.9748 J 28.2395
If I manually remove the spaces from the Arc commands like this:
G02 X23.9447 Y8.0243 Z-0.5000 I2432.7112 J-2189.4560 F50.0000
I work with natural materials a lot (mostly wood) that have a curve to them, so I am quite excited by Autoleveller and how easy it seems to be to use. In the meantime I'll modify GCodetools to stop using spaces.
