Autoleveller AE 2 stage levelling question
Posted: Wed Apr 03, 2019 9:24 am
Hello to everyone! I am very happy to try this small and useful software.
I just have one problem. Or maybe two...
When I try the 2 stage leveling, I make the first stage - the probing. Than I change my tool and go to autoleveller AE and make the leveling and save the file. When I load the adjusted file, in Mach3 and start the g-code, the machine goes to the position for probing. I saw in the Adjusted g-code that there is probing sequence. Am I doing something wrong? Or do I have to change something?
I want to use the 2-stage leveling for two reasons. First is that I make different toolpaths on the same material for two different tools. And also because my probe is mounted on the side of my spindle on a bracket. So I use the coordinates of the probe for zero. After the probing I intend to change the zero positions for X Y and Z where the tool is. The zero for the tool will be where the probe taking the first parameter, on default, the left lower corner.
So, my question is. Where are my mistakes? I will be happy if someone can help me!
