Probing not responding 6040 CNC mach3
Posted: Thu Jun 13, 2019 1:33 pm
I have a 6040 cnc using mach3, and I'm running into a weird issue.
When I start probing all seems good for the first couple touches, but suddenly it stops detecting and pushes into the board to the maximum probe height, if I let it continue it eventually goes back to probing normally but the final result isn't levelled at all, cutting very deep into the areas where the probing failed. You can check on the picture a board where I tried multiple probing grids and configurations.
https://imgur.com/a/ZcbV7s1
