no autolevel function on 5mm long lines in y direction
Posted: Sat Sep 14, 2019 2:42 pm
by neptunier
hello,
i am engraving stainless steel handles 10mm wide 140mm long. these are not very straight and therefor i use the autoleveller software.
however i ran into a problem with 5mm long lines along the y axis (x axis is the 140mm long side of the handle). the handles are not level in the y direction. i made my rpf file with 2 rows of probe points. the probe points at that location differ nearly 1/10 of a millimeter.
however the autoleveller software just uses the entrance point z value , so at the end of the line the cut is 1/10 deeper then it should.
do i miss something or is there a way i could solve that issue. working out that issue is key to the success of that project.
attached are the ogf, rpf and autolevelled file.
thanks for your help,
michael
Re: no autolevel function on 5mm long lines in y direction
Posted: Sun Sep 15, 2019 9:54 am
Hey Michael,
Thanks for all the information and files attached. It makes it much easier to diagnose.
I am using AE 0.9.5u2 which I presume you are too.
First I loaded the RPF file into AE which looked fine and as you described.
I then loaded the OGF into AE and expected to see a design in the drawing area, but was instead presented with this:
Looks blank. Also, it detected the x-width is 0, so this would explain why nothing is drawn and also why levelling isnt performed properly. I then opened the OGF in a separate editor and again there was almost nothing there.
I then opened the file in a text editor and saw only a few lines of GCode:
G00 G49 G40.1 G17 G64 G80 G50 G90
G21
(muster)
M03 S3200
G00 Z15.000
G00 X58.750 Y-2.907
G01Z0.577 F400
G01Y-2.200Z-0.130 F200
G01Y2.500
G01Y3.000Z0.736 F400
G00 Z15.000
G00
M5 M9
M30
Did you attach the wrong OGF or something?
Posted: Sun Sep 15, 2019 9:25 pm
I just had a thought on this. The uploaded OGF is probably just a quick test. and the lines within the file are well above Z0. AE wont level any line which is not negative. Could this be the reason for the problems?
Posted: Tue Sep 24, 2019 9:23 am
by neptunier
sorry for the late answer, i was on holidays.
i am using the newest version. the file is right, i just tested it again, in my autoleveller it works. it is just one 5mm long line with a ramp in and out. but the z height is the same on the 5mm long path although the z heights in the probe file are different on start and end of that toolpath.
i attach them again.
thanks,
michael
Posted: Mon Jan 27, 2020 11:11 am
by fredeopopo
Posted: Tue Jan 28, 2020 9:37 am
by neptunier
hi fredeopopo,
the problem i had was on an actual workpiece. then i tried to find out the problem and posted the ogf. maybe i did a mistake there, but the problem remains with the short line, with z below zero..
