SainSmart Genmitsu 3018-MX3
Posted: Thu Oct 24, 2019 2:33 am
Anyone have luck getting autolevelled G-Code to work on the above machine with Mach3? I appear to have some of the typical issues associated with USB controllers: During probing from the levelled G-Code, the probe just moves in X-Y and never descends to touch the board. I've tested out the probe in the Diagnostic Panel and it's working as expected (LED lights up when I touch the probe to the board). I can get the exact same G31 commands which appear in the levelled G-Code to work from MDI, but they seem to just get totally ignored when they are executed from a G-Code file. I also tried manually executing all the autolevelled G-Code commands up to the first G31 command from MDI and G31 works then.
I've tried all the recommended actions I've seen posted in various threads:
1) Prepend G31 with G4 Px pauses(tried x = 1 second, 5 seconds, 10 seconds)
2) Tried G31 with Z-1 and Z-5
3) M2002 macro
4) G52 Z0 instead of G92 Z0
Any other thoughts on what I can try to fix or diagnose the issue further? I'm certainly willing to try a few more things before I totally change directions.
3) M2002 macro
