Hello!
I'm having issues running autolevellerAE on Debian Stretch 9.9. I currently have java 11 installed, but each time I try to run the launch command:
java -jar AutolevelerAE[version].jar
I get the following error:
Error: Could not find or load main class com.cncsoftwaretools.autoleveller.Autoleveller
Caused by: java.lang.NoClassDefFoundError: javafx/application/Application
And as a result Autoleveller doesn't launch.
I've also tried installing java 12, but that results in the same error.
Any help on the issue would be much appreciated.
Thanks!
Trouble with Autoleveler and Java
Re: Trouble with Autoleveler and Java
Try downgrading. Ive heard reports it doent work on Java 10 and above.
Im stuck in the dark ages and compile using Java 8 u121.
Thanks so much, this fixed it!
Also, just to let you know, the tech admin tutorial pinned in the forum is no longer supported by the repositories they reference. It looks like the only way to install java 8 anymore is to find a bootleg .tar file
Thanks again!
Thanks again!
