AutolevellerAE won't run on my PC
CaptainSq
Post by CaptainSq »
hi,
Tried to get some answers under the Autoleveller software forum section but it seems to be dead. Maybe I can get some answers here.
I paid for membership so I'm really keen to get this issue sorted out.
The 0.8.5 version of AutolevellerAE don't run on my Win 10 PC. I have re-installed both 32 and 64 bit latest Java + the JDKs. Still no luck.
However, the "old" Autoleveller version starts an runs without any hickups.
The exe version of AutolevellerAE leaves no error message, it just never starts. When i try to start using a command line window with the "java -jar" command i get numerous error messages from the java engine. Most notable is "Error in Application start Method". I'm not a Java programmer so I can't read the trace info to find the real problem.
Trace dump:
C:\Users\Thom\Desktop>java -jar AutolevellerAE-0.8.5.jar
Exception in Application start method
java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:389)
        at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:328)
        at sun.launcher.LauncherHelper$FXHelper.main(Unknown Source)
Caused by: java.lang.RuntimeException: Exception in Application start method
        at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:917)
        at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$155(LauncherImpl.java:182)
        at java.lang.Thread.run(Unknown Source)
Caused by: javafx.fxml.LoadException:
file:/C:/Users/Thom/Desktop/AutolevellerAE-0.8.5.jar!/ALGUI/MainAL.fxml:23
        at javafx.fxml.FXMLLoader.constructLoadException(FXMLLoader.java:2601)
        at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2579)
        at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2441)
        at javafx.fxml.FXMLLoader.load(FXMLLoader.java:2409)
        at com.cncsoftwaretools.autoleveller.Autoleveller.start(Autoleveller.java:95)
        at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$162(LauncherImpl.java:863)
        at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$175(PlatformImpl.java:326)
        at com.sun.javafx.application.PlatformImpl.lambda$null$173(PlatformImpl.java:295)
        at java.security.AccessController.doPrivileged(Native Method)
        at com.sun.javafx.application.PlatformImpl.lambda$runLater$174(PlatformImpl.java:294)
        at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:95)
        at com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
        at com.sun.glass.ui.win.WinApplication.lambda$null$148(WinApplication.java:191)
        ... 1 more
Caused by: com.google.inject.ProvisionException: Unable to provision, see the following errors:
1) Error injecting constructor, java.lang.ExceptionInInitializerError
  at com.cncsoftwaretools.autoleveller.ui.controllers.ALGUIController.<init>(Unknown Source)
  while locating com.cncsoftwaretools.autoleveller.ui.controllers.ALGUIController
1 error
        at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1028)
        at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1054)
        at javafx.fxml.FXMLLoader$ValueElement.processAttribute(FXMLLoader.java:929)
        at javafx.fxml.FXMLLoader$InstanceDeclarationElement.processAttribute(FXMLLoader.java:971)
        at javafx.fxml.FXMLLoader$Element.processStartElement(FXMLLoader.java:220)
        at javafx.fxml.FXMLLoader$ValueElement.processStartElement(FXMLLoader.java:744)
        at javafx.fxml.FXMLLoader.processStartElement(FXMLLoader.java:2707)
        at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2527)
        ... 12 more
Caused by: java.lang.ExceptionInInitializerError
        at com.cncsoftwaretools.autoleveller.ui.ALModel.setDefaultPrefs(ALModel.java:113)
        at com.cncsoftwaretools.autoleveller.ui.ALModel.<init>(ALModel.java:103)
        at com.cncsoftwaretools.autoleveller.ui.ALModel.getInstance(ALModel.java:154)
        at com.cncsoftwaretools.autoleveller.ui.controllers.CommonFXML.<init>(CommonFXML.java:51)
        at com.cncsoftwaretools.autoleveller.ui.controllers.ALGUIController.<init>(ALGUIController.java:69)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
        at java.lang.reflect.Constructor.newInstance(Unknown Source)
        at com.google.inject.internal.DefaultConstructionProxyFactory$ReflectiveProxy.newInstance(DefaultConstructionProxyFactory.java:126)
        at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:111)
        at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:90)
        at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:268)
        at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1019)
        at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1085)
        at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1015)
        ... 19 more
Caused by: java.lang.NullPointerException
        at com.cncsoftwaretools.autoleveller.Controller.<init>(Controller.java:56)
        at com.cncsoftwaretools.autoleveller.Controller.<clinit>(Controller.java:39)
        ... 35 more
Exception running application com.cncsoftwaretools.autoleveller.Autoleveller
I'm sure some of you guys out there must be competent enough to analyze this and ask me complementary questions so we
can solve this.
Regards
/Thom
Re: AutolevellerAE won't run on my PC
Do you see a ".AE" folder in "C:\Users\Thom\"? and does it contain anything?
