Cannot Load OGF Problem
HamedElhoni
Post by HamedElhoni » Tue Nov 20, 2018 3:28 pm
Hi
The AutolevellerAE V0.9.5u1 gives the following error message when I tried to load OGF.
Screen Shot 2018-11-20 at 17.09.48.png (35.37 KiB) Viewed 459 times
I'm sure there is a negative value of Z axis. Also the same file was accepted free of error when I use Autoleveller V0.8.7.
Any one faced the same problem before?
Tanks In advance.
Hamed Elhoni
Re: Cannot Load OGF Problem
Post by Country_Bubba » Tue Nov 20, 2018 4:37 pm
This error code was added to the latest revision to find just such a scenario.
Previous versions didn't have it.
Open your gcode file in any basic text editor to verify the presents or lack of negative Z movements.
Chances are there are no negative Z's
Post by daedelus » Wed Nov 21, 2018 10:03 pm
As Art said, this error popup was added recently to warn users of the probable problem rather than just crashing abruptly.
If you cant find any problems with the OGF though, maybe paste the first 50 or so lines of code here and Im sure we will be able to find the problem and provide a workaround or solution.
HamedElhoni
Post by HamedElhoni » Sun Nov 25, 2018 8:53 pm
Hi
Thank you for your reply.
kindly find the first 50 line of the Gcode file.
N3 (Output format description: G-CODE for LinuxCNC)
N4 (Time: Sun Nov 25 22:41:57 2018)
N5 G21 (Units in millimeters)
N6 G90 (Absolute programming)
N7 G64 (Default cutting) G17 (XY plane) G40 (Cancel radius comp.) G49 (Cancel length comp.)
N8 G0 Z   3.000
N9 S10000
(*** LAYER: Layer 1 ***)
N10
(* SHAPE Nr: 0 *)
N11 G0 X  47.633 Y  20.584
N12 M3 M8
N13 G0 Z   3.000
N14 F150
N15 G1 Z  -2.000
N16 G2 X  47.618 Y  20.621 I   0.163 J   0.091
N17 G2 X  47.612 Y  20.652 I   0.140 J   0.043
N18 G2 X  47.612 Y  20.662 I   0.147 J   0.012
N19 G2 X  47.612 Y  20.672 I   0.154 J   0.001
N20 G2 X  47.615 Y  20.697 I   0.161 J  -0.009
N21 G2 X  47.630 Y  20.742 I   0.241 J  -0.052
N22 G2 X  47.652 Y  20.788 I   0.424 J  -0.183
N23 G2 X  47.674 Y  20.824 I   0.784 J  -0.447
N24 G3 X  48.088 Y  21.509 I -18.998 J  11.949
N25 G3 X  48.531 Y  22.318 I -15.934 J   9.247
N26 G3 X  48.856 Y  22.988 I -14.274 J   7.354
N27 G3 X  49.070 Y  23.477 I -13.418 J   6.143
N28 G3 X  49.196 Y  23.791 I -12.957 J   5.374
N29 G3 X  49.319 Y  24.140 I  -5.691 J   2.202
N30 G3 X  49.538 Y  25.086 I  -5.703 J   1.818
N31 G3 X  49.599 Y  25.735 I  -6.178 J   0.910
N32 G3 X  49.600 Y  26.259 I  -6.721 J   0.280
N33 G3 X  49.573 Y  26.673 I  -7.247 J  -0.262
N34 G3 X  49.524 Y  27.086 I  -7.842 J  -0.735
N35 G3 X  49.441 Y  27.557 I  -8.557 J  -1.261
N36 G3 X  49.335 Y  28.017 I  -9.754 J  -1.993
N37 G3 X  49.249 Y  28.331 I  -8.197 J  -2.082
N38 G3 X  49.081 Y  28.847 I  -9.375 J  -2.770
N39 G3 X  48.911 Y  29.293 I -10.850 J  -3.873
N40 G3 X  48.720 Y  29.743 I -13.189 J  -5.333
N41 G3 X  48.523 Y  30.171 I -16.633 J  -7.401
N42 G3 X  48.289 Y  30.650 I -23.523 J -11.205
N43 G3 X  48.082 Y  31.058 I -45.253 J -22.703
N44 G2 X  47.708 Y  31.859 I  10.652 J   5.461
N45 G2 X  47.421 Y  32.613 I  10.108 J   4.272
N46 G2 X  47.237 Y  33.218 I   9.981 J   3.378
N47 G2 X  47.041 Y  34.080 I   9.832 J   2.682
N48 G2 X  46.910 Y  35.097 I   9.804 J   1.779
N49 G2 X  46.886 Y  35.535 I   9.961 J   0.765
N50 G2 X  46.882 Y  35.976 I  10.119 J   0.331
N51 G2 X  46.901 Y  36.498 I  10.214 J  -0.111
N52 G2 X  46.969 Y  37.213 I  10.660 J  -0.662
N53 G2 X  47.077 Y  37.877 I  10.200 J  -1.323
N54 G2 X  47.212 Y  38.460 I   8.825 J  -1.738
N55 G2 X  47.406 Y  39.086 I   8.039 J  -2.147
N56 G2 X  47.656 Y  39.704 I   7.198 J  -2.544
N57 G2 X  47.945 Y  40.272 I   6.603 J  -3.005
N58 G2 X  48.560 Y  41.185 I   6.159 J  -3.486
N59 G2 X  48.848 Y  41.526 I   5.669 J  -4.498
N60 G2 X  49.051 Y  41.741 I   4.557 J  -4.096
Post by daedelus » Mon Nov 26, 2018 10:42 am
Just loaded this into 0.9.5 through my debugger and there were no complaints. So the problem must be further on in the GCode, an unrecognised line or something.
Would you mind sending me the entire file. Im guessing it is quite long so maybe email it to me: daedelus@autoleveller.co.uk
I can then run that in the debugger and find/fix the problem.
cheers
Post by daedelus » Tue Nov 27, 2018 3:39 pm
Thanks for emailing me this. I have since found and fixed the problem. Will release the update soon.
To explain what the problem was...
N1693 G3 X61.502 Y15.966 I0.039 J-0.143
N1694 G3 X61.501 Y15.966 I-0.000 J0.000
N1695 G3 X61.498 Y15.967 I-0.064 J-0.170
The above 3 lines were taken from the GCode you sent me. You see the second line the I and J are 0, 0. This makes the center of the arc the same as the starting point of the arc, and hence the radius of the arc is exactly 0.
This causes problems later on for Autoleveller and is why you get the popup essentially.
I fixed this by just adding 0.00001 to the X centre point to increase the radius fractionally. It feels to me like a nasty hacky solution but it works and it shouldnt affect anything else.
Post by daedelus » Wed Nov 28, 2018 2:58 pm
FYI I just released this 0.9.5u2. You can download from the members area or download the latest source and compile that. Hope it works.
Post by daedelus » Wed Nov 28, 2018 6:57 pm
Sorry, forgot to digitally sign the uploads from earlier. Have replaced the 0.9.5u2 files directly now. Doesnt matter if you already downloaded. All digital signing does is remove some security warnings from the downloads.
HamedElhoni
Post by HamedElhoni » Fri Nov 30, 2018 5:12 pm
I'm really appreciate your work to fix my problem.
I will try the new version of the AutolevellerAE.
Thank you
