Suggested enhancement or feature
adel314
Post by adel314 »
I just completed my first PCB using auto leveller and it worked very well. Indeed I did an etching test pass at 0.1mm and got a perfect outline of the board. However I did have one false start where some noise falsely triggered the probe and I wound up with a big air pocket in the middle of the board.
Even though I am working on improving my noise rejection and grounding, it would be nice to know if the probing does have an embedded anomaly - a simple prompt would help. On my subsequent runs I checked each probe touch to make sure it was okay. Hence the ability of the software to detect an out of tolerance measurement would be handy.
Other than that - a great bit of software...
Re: Suggested enhancement or feature
I think thats certainly possible although it does raise the question of what the tolerance value should be and whether this value is valid in all cases. For example, a particularly curved surface such as a computer mouse might need a different tolerance value to a PCB.
The other possibility is to perform the same probing process twice and compare the values for anomalies. This would be a more enforceable approach.
I would suggest you should make sure the surface and probe is as clean as possible prior to probing to try and avoid the false measurements
adel314
Post by adel314 »
Yes, you raise a good point regarding the broader application of the software. Thinking about this you could probably just have a set of profiles, one of them being say PCB (which I will assume is required to be perfectly flat) etc.
In the mean time I am aware of my issue and just apply a little caution during the probing.
