Page 2 of 2
Re: Manual Probing
Posted: Sat Apr 19, 2014 2:37 pm
by paulnd
I should have been more specific, sorry.
How do I add manual probing as described above in Linux CNC? I'm not milling PCB's but would like insert Z axis corrections into the gcode.
Re: Manual Probing
Posted: Sat Apr 19, 2014 2:57 pm
Autoleveler is a stand alone program. It should work with any g code file as long as you have the ability to probe it. As of now, it is assumed the probe is the tool that you will be using to do the cutting.
However, having said that, with some creative g coding, you should be able to do a probe with one tool and then cut with another.
So if we assume your going to "cut" with your "probe", you should be able to simply run your g code file through Autoleveler to produce a new file and it should work. After all, Autoleveler doesn't know if the workpiece is a pcb or a chunk of aluminum. :)
Re: Manual Probing
Posted: Sat Apr 19, 2014 5:06 pm
Vadim mentioned that he was using Mach3, but the part of the G-Code output that you will need to change should be identical in LinuxCNC. So, this:
daedelus wrote:Art is correct of course and has made me realise something.
If you run code through the AutoLeveller, you will see lines like this:
#500=#5422
G0 X-72.3148 Y-66.8981
G38.2 Z-1 F100
#501=#5422
G0 X-62.1816 Y-66.8981
G38.2 Z-1 F100
#502=#5422
G0 X-52.0484 Y-66.8981
G38.2 Z-1 F100
#503=#5422
#5422 is the variable which holds the current Z position and #500 onwards is the variable which the AutoLeveller refers to in milling later. So what you could do is replace the #5422 variable with you own number. You can then remove the probe lines before it. So the above code would become:
#500=0.012
#501=0.056
#502=0.023
#503=0.034
for example. I think this will do what you want.
is correct in Mach3 or LinuxCNC I think. Let us know if not or if I have misinterpreted the question.
Re: Manual Probing
Posted: Mon Apr 21, 2014 9:12 pm
by paulnd
Thanks, that's what I was looking for, I wasn't sure if the code would be the same for Mach 3 and Linux CNC
