Problem with lead-in
CitizenOfDreams
Post by CitizenOfDreams »
I tried to make an engraving where every trajectory started with a lead-in. Unfortunately, AutoLeveller seems to be messing up my lead-in moves...
Here is the original code. The cutter spirals down for 1 turn, then makes 1 flat turn:
G21 G90 G91.1 G64 G40
G0 Z1.5
( T14 : 0.2 )
T14 M6
G17
M3 S8000
G0 X33.9286 Y5.6548
G0 Z1.0
G1 F100.0 Z0.0
G2 F150.0 X34.95 Y7.8187 Z-0.0289 I2.0714 J0.3452
G2 X38.1 Y6.0 Z-0.0789 I1.05 J-1.8187
G2 X34.95 Y4.1813 Z-0.1289 I-2.1 J0.0
G2 X33.9286 Y5.6548 Z-0.15 I1.05 J1.8187
G2 X34.95 Y7.8187 I2.0714 J0.3452
G2 X38.1 Y6.0 I1.05 J-1.8187
G2 X34.95 Y4.1813 I-2.1 J0.0
G2 X33.9286 Y5.6548 I1.05 J1.8187
G0 Z1.5
M5
M30
And here is the autolevelled code. The cutter plunges down all the way into the stock, then spirals up. It seems that the lead-in starting point remained the same while the rest of the trajectory got properly autolevelled.
G0 Z1.5
( T14 : 0.2 )
T14 M6
G17
M3 S8000
G0 X33.9286 Y5.6548
G0 Z1.0
G1 F100.0 Z0.0
G2 F150.0 X34.95 Y7.8187 Z0.62273 I2.0714 J0.3452
G2 X38.1 Y6.0 Z0.63532 I1.05 J-1.8187
G2 X34.95 Y4.1813 Z0.54494 I-2.1 J0.0
G2 X33.9286 Y5.6548 Z0.49820 I1.05 J1.8187
G2 X34.95 Y7.8187Z0.50163 I2.0714 J0.3452
G2 X38.1 Y6.0Z0.56422 I1.05 J-1.8187
G2 X34.95 Y4.1813Z0.52384 I-2.1 J0.0
G2 X33.9286 Y5.6548Z0.49820 I1.05 J1.8187
G0 Z1.5
M5
M30
Here is my probe file:
0.99766,1.00547,0.01719
9.06797,1.00547,0.18281
17.13828,1.00547,0.36016
25.20859,1.00547,0.50781
33.27891,1.00547,0.66719
41.34922,1.00547,0.79297
41.34922,8.00547,0.75703
33.27891,8.00547,0.62266
25.20859,8.00547,0.46484
17.13828,8.00547,0.29297
9.06797,8.00547,0.10703
0.99766,8.00547,-0.05859
0.99766,15.00547,-0.12578
9.06797,15.00547,0.04609
17.13828,15.00547,0.24297
25.20859,15.00547,0.41953
33.27891,15.00547,0.59141
41.34922,15.00547,0.71797
41.34922,22.00547,0.67813
33.27891,22.00547,0.55000
25.20859,22.00547,0.37656
17.13828,22.00547,0.19141
9.06797,22.00547,-0.00937
0.99766,22.00547,-0.21875
0.99766,29.00547,-0.26094
9.06797,29.00547,-0.04453
17.13828,29.00547,0.17578
25.20859,29.00547,0.36094
33.27891,29.00547,0.53516
41.34922,29.00547,0.67578
41.34922,36.00547,0.65938
33.27891,36.00547,0.51953
25.20859,36.00547,0.34609
17.13828,36.00547,0.16484
9.06797,36.00547,-0.06094
0.99766,36.00547,-0.29141
0.99766,43.00547,-0.29062
9.06797,43.00547,-0.07578
17.13828,43.00547,0.14844
25.20859,43.00547,0.33672
33.27891,43.00547,0.51094
41.34922,43.00547,0.64766
AutoLeveller AE 0.7.8.
CitizenOfDreams
Re: Problem with lead-in
Update: AutoLeveller 0.8.7 non-AE works as expected:
G1 F100.0 Z0.0
becomes
G1 F100 Z0.648199
and the lead-in spirals down just like it was meant to.
G0 Z1.5
( T14 : 0.2 )
T14 M6
G17
M3 S8000
G0 X33.9286 Y5.6548
G0 Z1
G1 F100 Z0.648199
G2 X34.95 Y7.8187 Z0.622724 I2.0714 J0.3452 F150
G2 X38.1 Y6 Z0.635318 I1.05 J-1.8187
G2 X34.95 Y4.1813 Z0.544939 I-2.1 J0
G2 X33.9286 Y5.6548 Z0.498199 I1.05 J1.8187
G2 X34.95 Y7.8187 Z0.501624 I2.0714 J0.3452
G2 X38.1 Y6 Z0.564218 I1.05 J-1.8187
G2 X34.95 Y4.1813 Z0.523839 I-2.1 J0
G0 Z1.5
M5
M30
You seem to have a knack of finding quite rare issues :D :D Thats good though because any problem you can find and I fix is a problem that others wont encounter.
Ran some tests on the code you posted and I think I have found the issue and can offer a quick workaround...
AE assumes that any point which has a negative Z value must be a cutting move and autolevels the point. Since Z0.0 is not negative it doesnt autolevel it which is why this first Z moves to the stock instead of Z0.648199.
What I did was change the Z0.0 in the file to Z-0.00001, ran it through AE, and everything looks fine after. You can do the same, and also do a find & replace to track down any other points where Z is 0.
The reason the original AL works OK is because it autolevels points which have a Z <= 0 (whereas AE is just Z < 0). I thought AE was the same as AL in this regard but evidently not. I will fix this when I can but use the workaround in the meantime.
hope this helps,
CitizenOfDreams
I guess I'm a trouble magnet. :lol: Thanks for the explanation, now I see what is happening.
This raises another question though. If only the moves below the stock surface are autolevelled, what happens if the clearance plane in the original file was set too low? For instance, all rapid moves occur at Z=1, and the stock is curved so much that its highest point is at Z=2? Will AutoLeveller correct or at least detect this collision?
I guess the clearance moves would scrape the surface in certain places in these cases but this would be rare and would happen whether or not the file was Autolevelled. There is no way to detect this currently but if you use a probe file then you will be able to see the model of the surface in AE and it will tell you what the highest point is so you can tell if this will clash with your original clearance plane.
AL and AE break each line segment into smaller ones so they can be Autolevelled correctly. It seemed pointless and inefficient to segment and apply levelling calculations for lines where Z is > 0 especially as the original AL programs did not include probe file methods (RPF) and all calculations had to be written to the AL'd gcode file. However, it may be safer to level everything regardless of Z height.
Food for thought, as they say.
