Hallo,
I have yesterday used autoleveller and Mach3 and it works well. Now If I reload a new pcb board with the gcode vars in mach3 from autoleveller, I can see that the gcode vars are not deleted. Is there a way to reset this first to 0 or how can I reset the probe vales starting from. #500?
Thx druckgott
Mach3 and Autoleveller
Re: Mach3 and Autoleveller
Why do you need to reset Mach3 variables? The next program you run will simply overwrite them with new values as needed.
I think this was the problem but it was the probe value 2002 this was not set to 0 so I have problems with the softlimits on the next probe starting. I changed my vba script in Mach and now it's working.
