First try
chuckieboy
First try
Post by chuckieboy »
Hi
I've have been playing around with the free version for a short while and found it to be very good so I became and member and down loaded the latest version and must say I'm very impressed with it, perfect results can't wait to try it some more very easy to use too!
chuckieboy
Re: First try
:) Fantastic. Glad to help. Thanks for the feedback.
chuckieboy
Re: First try
I'm running windows 10 and now the autoleveller will not a file in autoleveller-0.60.jar (if I should use this version ?)
I get in the log file
Jan 20, 2016 8:22:21 PM java.util.prefs.WindowsPreferences <init>
WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0x80000002. Windows RegCreateKeyEx(...) returned error code 5.
Am I doing something wrong ?
Re: First try
I too get this log message. It is not a problem. In general "WARNINGS" can be ignored and "ERRORS" will cause you problems.
I can tell you where and how this warning appears, but not why:
When you browse for a file ALAE tries to open the previously used folder which should have been stored in the Windows registry somewhere. So when you browse for your gcode file it should take you automatically to the last known folder that you used. In the code, I create a registry entry for this, and when I do, the warning shows up. The strange thing is, ALAE browses to this folder, and everything works as expected despite the warning saying there is a problem, so you really can safely ignore this.
chuckieboy
Re: First try
I click on open button but the button does not work it will not let me open a file. If I click autolevlel then get error message that no G-doe is loaded so I know this button works the clear I ant' say because I can't open a file
Re: First try
Hmmm, so I guess the warning message does hold true for some people. Let me see if I can find a workaround. Does the original Autoleveller work OK? Does the browse button work OK there?
chuckieboy
Re: First try
I've tried autoleveller version 0.8.7 and 0.77 they both open the G-Code just autoleveller 8 0.060 the open button does not work
Re: First try
Thanks for checking
Its hard to debug this one because I cannot replicate the issue on my machine. However I have applied a workaround which should do the trick and it will be in the next release which should be very soon.
Got a bit of flu at the moment and feeling like a dogs dinner currently so bear with me.
chuckieboy
Re: First try
I hope you get to feel better soon, I still could not open any files so I thought I'd try something and went through the registry and searched for autoleveller and deleted it all, re-opened it and I now can open files and create the level code. Will try it again and see how it goes and will let you know. I'll also wait for next version when done
chuckieboy
Re: First try
I've tried it again this morning and still get the same error, Will not open file, This time I went through the registry again and found the that if I delete the bit in the attached picture it works normal
Hope this helps in locating my issue
